Hole in topper, need suggestions
Shaners
Hey All,
Figured this was as good a place as any to ask about a fix.  I recently bought an aluminum topper for my 91 S-10 p/up "winter beater".  Only thing wrong with the cap is that it has a gash about 4 in. long in the roof (only paid $50 for the top so I figured I could fix it).  Went to a local place that sells truck caps and was able to get a new "scrap" piece of aluminum about 18" x 18" in the same color.
Here is my thought; cut to size and put a piece on top, another piece on the inside top and apply silicone to both and rivet them together.  Just not sure what type of silicone to use.  Also thought of using furnace cement (used for sealing duct work)  Think this will work?  Any other ideas on how to seal this off would be much appreciated.  Of course this is not the most aesthetically pleasing fix I realize, just enough to keep the water out!
TIA,
BIG BLUE
Do you have access to or know anyone that can weld aluminum?  If so that's the route I'd go.  Otherwise drill a few holes in it and rivet it to it.  Then go to the hardware store and get some type of water tight sealant.  Somthing in a caulk gun would work great.  Just squirt it on and work it into the cracks.  Do a few coats from the inside and out just to be on the safe side.
as long as you use 100% silicone, and not a silicone/acrylic blend you should be fine.
may also try silicone adhesive.. will add a little extra bonding, and will still be waterproof
The aluminum skin is so thin I think it would be very hard to weld it without burning a hole in it.  I think the silicone adhesive and a rivit gun are the way to go...
you can weld aluminum, you just have to be good.  They make a foot pedal that allows you to decrease the amperage as you go.
But, I'll agree w/ you.  A piece of metal, some rivets, and a good sealing job would be the best way.
You can TIG weld it, but the surfaces have to be very clean, easy to blow a hole in it.  Your repair sounds good.  Look around you can get clear or aluminum color silicone.  I don't think you need to put another piece under it, you will probably get a tighter fit just using a new top piece riveted to the shell.
welding aluminum is hard but try magnesium or titanium. now work talking skill...me being a metalsmith you could go either way, the the easiest way for you would be going with the lap patch and doubler on the inside and sealing and riveting it you should be fine using a sealing adhesive that has good corrosion resistant properties. just make sure you seal around the out side edges of the patch to make sure water cant work its way under the repair. hope this helps
This is absolutely correct. The metal is too thin to weld. Rivets and silicone are the way to go. I would put vent tape on the inside to seal it.
    • Just want to make sure it is covered by Special Coverage N232395310 Evaporative Emission Purge Pump 2021 Silverado 1500 Custom 2.7L L3B ~100k miles I'm getting DTCs P146B and P146F. VIN 3GCPWBEK2MGxxxxxx   I spoke to a person that works at GM and he said it is not covered after checking my VIN.   Is there anyone here who currently works for a GM/Chevrolet dealership and has access to GM Global Warranty Management / Investigate Vehicle History who could explain how the VIN eligibility is determined?   thank you
    • Thanks for all that information, I might purchase one and see if it will work for me, if not they may let me return it! Yes for sure the tires are definitely within limit for my truck empty, and when I do tow I'll definitely make sure to raise the rear psi for the amount of weight that's going to be on it.
    • Yes exactly, more and more these days people/companies are afraid of liability issues so its easier just to say no rather than risk putting their neck on the line.    I will say with the Autel unit or when I used it last year on my truck, it wasn't like I could choose the 2025 model year or even the 2024 model year as that option was not there to manipulate the placard pressures but had to go back to 2023 or there abouts and then it showed up as an option, odd but that was how the software was then and I can't say one way or the other now as they throw out updates every so often. I still would talk to your tire dealer though to start with and they may do it for nothing but also they may have a comment on a better unit to purchase. All I know is that one of the large tire shops in my area happens to use these Autel units for their use and set them up to use the wifi and all of that jazz for constant updating because each tire tech has one handed to them by the shop but I just plugged it into my laptop to update it and yes if one is bought it has to be registered so you can get the link to do updates and then the unit has to be updated before its even used. I am not at all techy so it took me a bit but anyway just a heads up for anything you buy, most likely it will need to be connected to a computer to access the internet to have it updated to the latest software version before you can put it to use.   If your truck is near empty, those tire pressures you listed are a very safe upper range pressures to carry the weight, both the front and rear as I know they could be run lower yet with an empty truck. And if its a trailer and not some motorcycle your going to strap onto the front of your truck on a rack, you shouldn't have a need to inflate your front tires if your at 55 front already, its the rear ones that would need more air if you have much hitch weight.
    • Thank you, I'll check that Autel scanner out and see if it will work for me! Ya I can see GM's point of view if they lower the psi set value for someone and the person sell's the truck and the new owner puts the factory tires back on then their could be liability issues cause the psi warning light wasn't coming on when the tires were under inflated for towing their load and then it might be able to be traced back to GM lowering it.
    • I had a similar but different response when I talked to the service manager where I bought my truck in that he said GM corporate won't allow them to lower the placard pressure setting as they would get their hand slapped but that of course they have the ability to make that change. His suggestion was simply go to a tire dealer or third party shop that is willing to reset the pressures lower. However I chose to buy a tpms tool and partly based off of this very forum as it had been proven to work on the 2024 model ( Global B system ) and while I could have paid lots for a full two way diag tool, I didn't want to spend that much and bought the recommended Autel TS 508 and it will reprogram the 2025 model and assume it should do the 2026 as well. However the tool is rather proprietary to reprogramming Autel tpms sensors so that is a function I will never use, where as a real two way scanner would have many uses but also have yearly subscriptions etc where this 508 is free updates for as long as they put updates out for the unit. In any event it worked to lower the placard pressures and I often use it to adjust my actual tire pressures although will check with a mechanical gauge as well sometimes just to make sure that tires tpms sensor isn't lying to me.    My suggestion is either buy a tool that you know will work to adjust the system or start out by getting the tire shop you bought your tires from to reset your truck and if after that you still want a unit to do it yourself, get one at that point.
