Looking for advice, just rebuilt my 2000 chevy 5.3l. The idle is rough. I have looked for vacuum leaks and could not find any. I looked at the timing and it is at 8 to 10 degrees. When I put the engine together I lined up the marks on the sprocket as directed, top at 6 'o and bottom at 12'0. I also conducted compression check to make sure for leaking heads and such. My compression was at 125 with no leak off.
Need to be looking at data from a scan tool. Watching fuel trims to see if they are really high still to indicate a vacuum leak or low fuel pressure.
Could also be a bad IAC or something with the MAF but we are only guessing. Idle ignition timing on a scan tool should show around 20ish at idle give or take a few if everything is working right.
did you rebuild it to stock?
all the exhaust manifold bolts are present and you put new gaskets/seals in the manifold to exhaust pipe joints?
The scan tool shows' full pressures are good. Both rails. I looked for vacuum leaks and cold not find any. I am starting to lean towards a timing issue.
Well no wonder it runs rough, you put a larger camshaft in there.
You need to get the vehicle tuned for the camshaft change.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,025 Guests (See full list)
