9 minutes ago, bruceb58 said:
If my truck is going to sit for 2 weeks or more, i have a solar panel and a solar controller that suction cups on the windshield. It's a 50W panel and I attach it to the vehicle via Anderson connectors.
My experience with  previous new vehicles is that they last 2 to 5 years. I think it all depends on how discharged the batteries have gotten while sitting around either before going into a vehicle or how long the vehicle has been sitting before sold. It's always interesting that the batteries in my new vehicles that last the longest are vehicles I special ordered. They sit around the least before being sold.
That's a good rig you have there for maintaining the battery although I realize that would not work well in my situation since its typically parked in a garage or one of the equipment sheds to keep it out of the sun and weather.
I was thinking of that thought as well when you mentioned special ordered vehicles as mine was built in the middle of one month and delivered to the dealer about a month later. I have no idea what the lead time on a battery build to being installed into a vehicle at a factory is but at least its not connected to anything to draw it down and the same theme goes for batteries bought over the counter at whatever retailer as some of them may have batteries kicking around for too long if its not a quick selling item.
One thing I have thought about with the GM conglomeration of that fused assembly that fits over the top of the battery, if an aftermarket battery of the same model type is made to the same dimensions so that the plastic unit fits over the battery correctly as there is no room for error in how the positive connection is locked into place on the cover and the cover even clips onto the edges of the battery if I am not mistaken. Just wondered if anyone had bought a different brand battery with one of these newer trucks and if it fits or is an issue due to that cover.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   5 Members, 0 Anonymous, 1,321 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
