Hi all,
Purchasing a 2018 Escalade with 10-speed, towing package and G80 rear end on Monday. It has 73k miles and I intend to replace all fluids, filters, plugs + wires proactively. I understand it's been well maintained but I want to have a good baseline.
I was looking at the owners manual for fluid capacities and types but it appears to have been superseded. I was hoping someone here could let me know if the following would work.
Motor oil - 7qts Mobil 1 0w20
Coolant - 21qts Dex-cool and water + water wetter
Transmission fluid - 12qt Dexron ULV
T-case fluid - 2qts Auto-Trak II
Front diff - 2.7qt AC-Delco 75w90 hypoid oil
Rear diff - 3.5qt AC-Delco 75w85 hypoid oil (no LS modifier)
Brakes - 2qts DOT 4 Motul 600
Plugs - AC-Delco 41-147
Note on brake fluid - I take our cars into the mountains a lot and like the safety of a high boiling point fluid
The L86 engine takes 8 quarts of oil with the filter.
Don't mix DexCool with water wetter.  It only works if you are using less than 20% Dexcool with water.  If running 50/50 or so, it doesn't do anything but drain your wallet.
We have used up to 6 quarts of brake fluid to change it all out and do an ABS bleed.
Run the severe service schedule from now on.
    timcpeters
    timcpeters
  • Who's Online   1 Member, 0 Anonymous, 1,185 Guests (See full list)
