2024 Silverado 1500: integrated 7-blade plug. Trailer brakes lock up instantly upon connection. I have a fleet of trucks and cargo trailers. All have 6-pole connections. All attach and function properly including all electric brakes. My truck locks all brakes. I have two 7-blade to 6-pole adaptors. One center pole hot, one center pole brakes. Both lock brakes without any brake application and 0 gain. All lighting functions properly. All trailers have been inspected and function properly when attached to other fleet tow vehicles. I have tested the 7-blade with each adaptor to verify proper wiring as well as no bleed from hot to another pole. I'm stuck!
You need to carefully determine what wire/functions go where in your trailer plugs. Don't use online charts or wire colors. Your trailers may not be to any particular standard. Once you know what function is where on your trailer plug, adjust your 7 to 6 adapter to match. Start with the 7 pin side, confirm that the adapter matches the trucks functions. When you are confident that you know the functions being input to the 7 pin, connect them on the adapters 6 pin outputs matching them to you trailers plug.
Do not swap adapters from truck to truck, hopefully all your trailers are wired the same and one adapter in your truck works for all your trailers.
I would also suggest to change all your trailers to the modern 7 pin plug (match your truck), these are essentially industry standard now across all manufacturers. Any factory plug from the mid 2000's would be able to connect to your trailers without an adapter.
What braking system is on the trailers?
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,270 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
