Ok so here's the story.
I have a 2022 Silverado 2500 6.6 gas with 35kmiles  and I absolutely love the truck! Bought it for my slide in camper and I now have a 24ft rpod I tow with it.
Couldn't be happier.
At about 10k miles I started periodically smelling coolant. Also noticed a bit of oil consumption but I've owned 3 GM LS/LT trucks so I thought nothing of it.
At about 20k miles the coolant smell was persistent and I felt like the oil consumption was more than I was used to...even for my previous 250k mile truck. I looked online and couldn't find anyone with the same problem. I was planning a move from CA to CO with a few 12k lbs tows across the rockies so I took it to the dealer. They had it for three days and finally ended up replacing the passenger headgasket. I got the truck back and smelled coolant again a few days later.
Now in CO I smelled coolant regularly but ignored it. Summer 2024 I drove from CO to MA with my slide in camper doing about 75-80mph. After about 1500 miles i noticed about a 1/2" drop in coolant and about a quarter of oil burnt. When I got back to CO I took it to the dealer with about 28k mile. They did a pressure check and found nothing. Typical. They added dye to the coolant and sent me home.
 Drove for about a year and regularly smelled coolant but did not see the coolant level go down. Also my oil consumption was acceptable.
This fall I took a trip to Utah with my trailer. Maybe 5k in trailer weight and 1k in additional payload. I felt the truck was under powered. After the there and back 1k mile trip I burnt through 1 quart of oil and my coolant dropped by 0.75".
Took it back to the dealer right after the trip at 35k miles. I told the counter to come out and smell my truck, it reaked of coolant and they agreed. Finally, someone was on my side.
They founds that my passenger head was cracked near the V and at the very back. However they cannot explain my oil consumption. They are pushing tk have GM replace the whole engine.
Anyway I do love the 6.6 gas and I think this is an isolated issue as I have not seen it elsewhere. I just got a dud. Posting this as a statistic really.
I will update on what GM decides to do.
Al
  • Like 4
Al
That is not good to hear when issues like that persist and yet can be hard to find as coolant evaporates off if not excessive and when it leaks only when hot, now if its literally streaming out and puddling on the ground then there is somewhere to trace it back to the source. Luckily and after a lot of effort on your part it was finally found but then there is your oil usage and you felt you were down on power. How much oil would you say it is using and I assume its varied according to being driven empty vs towing.
Because you had it at the dealer multiple times, did they top of the reservoir to a specific line as I haven't spotted any markings on the plastic bottle or I am not looking in the right place as to what the operating range is even supposed to be, I've never had this issue with any other vehicles trying to figure out where the cold or hot level was on the tank. Is it supposed to be just at the top of the mold line where the two halves of the tank come together ?
Yes, it has been hard to find. The second time they added dye to the coolant which they said helped find the coolant leak.
As for oil, I was towing 5k lbs and burnt 1 quart of oil in just 1000 miles. That is excessive IMO.
My understanding is that the cold level fill for the coolant is at the mold-line.
I have been approved for a new engine! Glad that GM and the dealer are finally working to resolve this....I wonder if it has anything to do with the fact that this is my third visit for the same issue and I fall within the Lemon-Law now.
Presuming the engine does get replaced, the head work was somewhat of a waste but it also showed GM that there was an issue with the engine. At the time they replaced the head they would have seen if there was scoring in the cylinders if any coolant had been entering in that direction as well on that bank of cylinders. To me that 1000 mile/1 quart seems off from what some on here have experienced with their engines but the odd one has said they had an oil use issue. It would be nice to know what the reason is behind those engines out there that are using oil. I have few miles on my truck and have changed the oil a few times just to flush out break in metals as the filter doesn't capture them all and have not been working the engine either so have not noted any noticeable usage but its not a good example as I would have to be asked that same question after I had 100000+ miles !.
I have been keeping an eye on my coolant level and so far so good as per not dropping but again just odd how GM designed that bottle to give no indication on it as to where "full" is.
It will be interesting after they drop the new engine in, how it runs power wise in comparison and of course the oil consumption aspect. I know GM doesn't expressly say to change the initial factory oil early in so many words and yet says don't tow for the first 500 miles ... but then says change the oil before you tow. Some genius lawyer wrote that brain twister LOL but anyway I personally subscribe to the concept of changing the factory oil out after 500 miles and then after another 1000 or so miles accumulated on the second oil interval, it sure can't hurt. And beyond that, well I am one that tries to stick to that 3000 mile change interval with cars or pickups over the years but again that is what I am used to doing and not sending out samples that give the engine a chance to speak up and tell what the real picture is.
Hopefully you will have the opportunity to give updates on here as time goes on after the new engine is installed to see how that has worked out for you.
Al
Our team is interested in learning more and working alongside you throughout repairs, Alex. So that we can connect directly, please email us at [email protected]. In your email, please include your full VIN, full name, dealerships name and address, and your trucks mileage. By sending us a message, you consent to the information you provide being monitored and recorded by GM or those acting on GM’s behalf, subject to the GM Privacy Statement:  https://www.gm.com/privacy-statement.
    • There was talk over the last couple of years that the contract to build these trucks between GM and International would not be renewed.  International moved production of all their other trucks besides the companion CV model out of the Springfield plant some time ago when they opened their San Antonio plant.  That left Springfield only building the Silverado Medium Duty, International CV Series, and some Express/Savanna long wheelbase cutaways.  International also put the plant up for sale some time ago.  This all answered my earlier question as to why GM and International did nothing with these trucks since they were introduced, as they had basically become a market 'placeholder' with a finite life.    The Silverado Medium Duty/International CV trucks were interesting combination of a GM powertrain, electrical system, and K2XX Silverado cab with an International chassis that was supposedly designed for a step-van type vehicle they never produced.  They were manufactured in International's Springfield plant along with the IH MV series initially.  When first introduced, there was much talk that the Silverado Medium Duty/CV would eventually get a gasoline engine option along with other upgrades and GM and IH would work on a class 6/7 joint venture truck.  This was before VW bought Navistar out, after that happened no more was said.  Draw your own conclusions...   About the time talk started that the GM/IH joint venture was not going to be renewed, rumors started that GM would develop a new line of medium duty trucks themselves.  The story is the new trucks will be part of the next generation HD's due in 2028, and will still feature a 'straight rail' chassis design that the current medium duty has.  GM views this as a desirable feature that differentiates their truck from the competition.  A gasoline engine option is also expected.  As the current Silverado Medium Duty remains in production until September 2026 and there is still a lot of inventory available do not expect any official word for some time.   I believe GM remains committed to their successful partnership with Isuzu, and all the LCF models will still be available from Chevy Commercial dealers.  Isuzu is on the cusp of opening a new large plant in South Carolina and there is also speculation that this may result in new product for both Isuzu and Chevy Commercial dealers.
    • drive the truck back to the dealer and complain that the button works.
    • I have a 2026 2500 HD Ultimate. My phone app says there’s a software update available. It’s something about improved battery management and something to do with the running boards. I follow the instructions for the update but the “Check for Updates” option is greyed out in my settings menu. Has anyone else seen this? How did you resolve it? The help message just says “see your dealer” if the download doesn’t work. I’m just trying to save a trip.
    • Fuel mileage?  That's all how you use your right foot.  Exhaust will give you sound.   Stock exhaust 5.3 is 2.75" diameter piping.     If the truck is nice and worth putting some $$ into it, I'd go for a Corsa catback.  I had one on my 2019 old body 5.3 and it was just perfect.  Zero drone, just driving around and cruising on the highway you'd think it was stock, but when you opened it up it was like a Camaro with the factory dual mode.  Corsa bumps their catback to 3in diameter.
