I need just a simple work truck and I'm looking at a 99 Silverado 2500 for sale with 218k miles. It's got a little body rust, but they're only asking $2700 so I'm good with it. I'll make sure to check for excessive frame rust before handing over any cash. It's got a 6.0L 8-cyl engine with 4x4 and auto transmission. I'm familiar with the 1500 series and engines, but I don't know anything about the 2500s. Is this truck thought to be as reliable as the 1500s up to 2006? Or does it have some kind of fatal flaw where I want to avoid it? Thanks.
^6.0 is pretty bullet proof but not very good on gas, probably a 4L80e trans which should be fine as long as it wasn't plowed or abused, frame rot and cracks would be 1 concern, check the ball joints, they tend to wear out regularly, look at the rear spring hangers and the rear cab mounts
Being a 1999, those used cast iron cylinder heads with what I recall were some sort of fiber/paper headgasket. The later years got aluminum cylinder heads and MLS headgaskets. The early trucks were more prone to headgasket failure from what I remember. Not the end of the world but would be nice to know there were any history records on the truck.
If you're lucky, maybe someone already swapped in a new engine in the 26 years that thing has been around.
Transmissions are strong being a 4L80e, but like said they can die from lack of fluid changes or it was a plow truck/pulled heavy trailers everyday. Frame rot is a big killer in the salt states. Always check that first.
    bellssn690
    bellssn690
  • Who's Online   3 Members, 0 Anonymous, 905 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
