I went to my local dealership for an oil change, and when i received my truck back the entire passenger turn signal/running light assembly stopped working. The dealership said there are no error codes and the assembly is $1200+ just for the part. Has anyone else had this issue and is there a work around of any type? The truck is a 2022 Silverado Z71 Crew Cab
Edited by 22z71
was it working before?
I would start off with assuming there is a wiring/power/ground/connection problem, rather than selecting the most expensive part of the circuit to throw at the problem.
It was working fine prior to going into the dealership. Never had a problem out of either one. Then when it comes out it suddenly stops working. They told me that's what needed to be replaced. I'm going to be checking fuses and wiring in the morning, just was curious if anyone had had a similar experience
Well, I would be complaining to them aboot messing it up, as it is totally unlikely that it just happened to fail while they had it.
It is WAY more likely it happened by something they did, either unintentionally or intentionally.
    d.lowrey
    d.lowrey
  • Who's Online   4 Members, 0 Anonymous, 2,335 Guests (See full list)
