2021 Tahoe with 5.3 gas & about 60K miles.
Short version:
Parking Brake refuses to release after a brief stop (gas station, rest area). We are not manually engaging the parking brake, it is setting itself.
No consistent means of resolution, other than waving a dead chicken above our head in a circle for an indeterminate amount of time.
Long version:
Drove vehicle more than 30 miles, stopped, shut off, did not manually set parking brake (never do). Came back to vehicle 5 minutes later, started, had red "PARK" lit on dash. Put vehicle in drive, vehicle would not move, acted like the parking brake was applied. Applying throttle did not move the vehicle, up to 1/2 throttle.
Things attempted to resolve:
Restarted vehicle.
Shut off, got out with key fob, closed door, got back in, restarted.
Attempted to put in brake service mode, steps would complete, but the yellow P with wrench would not illuminate nor the "brake service mode" message. Rationale was to forcibly disengage the parking brake by entering service mode.
Shut off, opened/closed every door, got back in restarted.
Brake service light illuminated, red "PARK" light was still on (flashing or steady, not sure). Vehicle was able to drive off.
The above worked this one time. I presume all of the steps are just coincidental.
Few weeks later, hopped in vehicle after had been sitting for a couple hours, fired up and noted "PARK" lit on dash, which went away within a second or so after putting it in drive, there was nothing noticeable about the parking brake being engaged and we never manually engage it. The "PARK" light is normally never displayed.
A couple weeks later....
Vehicle driven for an hour, stopped and shut off for 5 minutes. Come back and "PARK" light illuminated and parking brake appears to be engaged as vehicle won't move.
Tried all of the above (get out, open/close doors, etc).
Had do steps for brake service mode, but would not activate (no P/wrench light). "PARK" still illuminated in red on dash.
Investigated battery and had thoughts on what they could do to temporarily disconnect the battery. This mostly accomplished "more time" spent and nothing was actually done.
One more attempt to start the vehicle and this time the brake service mode engaged, with the light and a message affirming it. Vehicle could then be driven.
This is an 2021 and I'm pretty sure we have not replaced the battery. I've seen others indicate that the battery is a magic fix. I'm skeptical it's related to this since we are able to easily start the vehicle multiple times in a row and once started, it should have adequate power to disengage the actuators.
We live in Michigan and do have plenty of salt driven through in the winter. Is there corrosion happening on the parking brake actuators? They are the original brakes. I've not had these apart; did have an 20 Silverado apart for a brake job and don't recall seeing anything exposed on the actuators to be concerned about, other than the caliper itself could be getting gunked up.
Edit to clarify it is the "PARK" light that is lit; not Brake as I originally had.
No codes.
I do see low voltage on the scanner when the vehicle starts (10-12v) and it takes it several minutes to get up to the 14v range. Maybe it is a battery.
I can manually engage the park brake and disengage. Parking on a hill, it will automatically engage the park brake. You can hear the actuators and the light on the dash matches what it should be doing.
I can just put it in D and take off and it will disengage the park brake on it's own. That's when it's working as expected, not in the "won't disengage" instances.
Other thoughts?
Edited by 2TrakR
I have a 2021 also. It will automatically come on when parked on an incline. My driveway is not very steep but it comes on everytime I park at home. You have to push the park brake button to turn it off. It does not take much of an incline for it to activate.
Inconsistent parking brakes is concerning to hear from our valued owners like you and we want to know more as soon as possible. Safety is a top priority for us. Please visit https://s.gmc.com/support-request, fill out the support request form with details of your experience, and a member of our team will follow up with you with further assistance.
    hotfish
    hotfish
  • Who's Online   7 Members, 0 Anonymous, 618 Guests (See full list)
