Removed sons rear diff due to loud howling noise going down highway. got different diff and replaced it. Want to get rid of this from my yard.
What years does tihs fit 99-07 classic?  GMC Sierra and Chevy Silverado 1500 I assume.
What something like this worth if listing to say FB or other locations online to get rid of?
Gotta be worth something I would assume.
thanks for input
It's only value would be in scrap metal. No one is going to buy a rear diff that needs new guts. The scrap metal value in my area is $200 a ton so it might be worth $10
thanks for input. just looking to see what years it will fit for others asking that i know.
    ballencd
    ballencd
  • Who's Online   5 Members, 0 Anonymous, 713 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
