I'm putting in an A-pillar pod/gauges, and I'm asking if anybody can identify a (preferably) fuse for a switched power and illumination circuit on the driver's side interior fuse panel. Offhand, everything I checked with a test light was constant-hot, and I'd much rather uses a piggyback fuse. I can certainly find a wire, but I'd rather not half-tap.
Thanks in advance for any help.
Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
The upfitter kit is quite a kit! However, GM doesn't want to install it so they give you the parts and show you the door.
You get 5 buttons and a separate fuse block as well as some large fuses that got in the battery covers. There were already installed on mine truck but nothing behind them (see the picture). I think the button install would be fun cutting into the plastic but overall, I really like the kit.
These are great and can be set to on all the time or switched by the key.
On the fuse block you get fuses and relays which makes it easy to connect lights or other high draw devices or gauges.
What gauges are you getting? If Banks, they have an OBD connector which makes connecting them easy, speaking from experience. Some other gauge pods will do the same.Screenshot2024-11-17at12_49_34PM.thumb.png.6f081b8661f69310bdf943c87f076f4d.png
So far I have Diode Dynamics fog lights and my dash cam connected. Working on more items to connect.
    mark2
    mark2
  • Who's Online   5 Members, 0 Anonymous, 628 Guests (See full list)
