I’m looking at putting a lift in my 2024 gmc sierra 1500 elevation trim, has anyone had any luck with fitting a bigger tire under the rear for a spare?? Was gonna go with a 4 inch zone lift Also what wheel and tire size setup are you all running? Wondering if I can get away with keeping around the stock size a 33 inch, and just get some new wheels to have enough back spacing then I can just keep my original spare tire I have under the truck now.
?  You don't NEED to install new wheels or tires after installing a lift kit.
People install lift kits in order to run larger wheels/tires, and then may need to get wheels with different offsets for these larger tires, so they don't rub.
That’s what I’m wondering is if the stock backspacing of the factory wheels will clear new upper control arms and such
I would expect that to be lift-kit dependent.  If the kit has interference issues w stock wheels, then the kit/manufacturer should indicate that somewhere.
Yes your absolutely right, I been looking at the 4 inch BDS one and it acutely states you can use the stock 20’s just not the 17’s or 18’s, I also didn’t realize that with my 275/60r20 stock wheels I’m already running 33 inch diameter wheel setup lol so I can just run my stock wheels and tires atleast to start.
    • Looks nice. I still have my 2000, 1500. Bought a 2025, 1500 for retirement. Feels solid. These trucks have a bad rap on the internet. My brother has a `24 1500, 5.3 with 52,000 miles. No problems at all. Mine hasn`t either but mine`s only at 12,700 miles. Have seen some of these things with 100,000 miles with no problems.
    • Howdy! New to the forum of course! My name is Casey, just picked up a 2024 high country midnight edition. First “new” truck in 24 years for me. Driving a 1998 Z71 since 2002. Have been on the GMT400 forum with lots of good info and help there. Nervous about driving these newer trucks and all their electronics…. Did a lot of work on the Z71 myself over the years. New truck is definitely a nice upgrade after 24 years. Photo of the old and new, still keeping the Z71 - has 320,000 miles on her and still running well!
