Changing front axle seals
My brother and I are trying to change the front axle seals in his 95 IFS chevy 4x4. We have the half shafts off, and the housing dropped. Now how do we get the axle shafts out of the housing? We pulled the vent plug, and can see the diff, but don't see any clips holding the shfts in. Help
driver side axle should pop out with a a little force
ie hammer
the passenger side is diffenent you have to unbolt the
5 bolts holding the extention on, seperate, disasemble
i think it's a snap ring. reassemble properly
clean sealing suface. seal with anerobic sealer
not too dificult but you have to know what your doing
done a couple of these.
Put two wedges chisels or screw drivers on either side of the flange for the axles.
they will pull out. they have a c clip that compresses on the spline when you pull them.
Warning on the drivers side your ok but the pasanger side you need to reomove the shaft going out to the pasenger end 5 or six bolts, Its were the sending unit for the 4 wheel drive is locateed too.
There is a washer you have to get back on the end. If you dont do this you cant get the passenger side back in. Washer is not linned up.
Remedy for these known seals.
In 1998 they finally changed the design from a cheap drive shaft type seal to a big thich bad ass seal.
there thicker.
You can buy the 98 seals then get your shafts turned down like 80 thousands farther down towards the flat half shaft flanges.
Or get 98 shafts. Ther the same shafts just more machine right to left to accept the wider seal.
I worked in a machine shop so i just turned them in a lathe.
If you try to use the new seal without doing this the little clip on the spline wont reach its slot.
If your going too keep the truck a while put in the new seals.
Never have to do this again.
Eric :confused:
    • Correct.  2019-2021 model years are serviced by a different p/n.  19420611.  Recall 2021s use 19420611.   The recall engines 2022-2024 model years are serviced with 12740076.     The difference between 19420611 and 12740076 is GM changed injector size for 2022.  The injectors are smaller on 12740076 with smaller injector bores in the cylinder heads to match the smaller injectors.  So you can't install a 19420611 in a 2022-2024, and you can't install a 12740076 in a 2019-2021.     Both engines are the replacement engine p/ns that are in the L87 recall.  So both of these are the updated engines.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
