Apology for recent actions
General Lee 01
I must apologize for profane language I used in a certain title that I chose to use earlier this week. It was childish, and un-proffessional of me to do that. Im sorry. :confused:
I am a simple human, and simple humans make mistakes, I'm by no means "perfect".
For 3 years, Ive made actions & decisions as a moderator that I could stand behind and be very proud of myself for. Well, that action cerainly isn't one of those that I stand behind, nor do I feel proud of.
With that said, I hang my head in shame before every member of GM-TC, and ask for forgiveness, AND to forget this shameful incident. As I comtemplate my future with here.......
Eh, we all have our downfalls sometimes. It's not like we've never read or seen thw word before. LOL, and I bet we've all screamed it once or twice when we're driving. :confused:
As long as you never trade a :sleep: for another brand, I'll always like you :chevy:
Ok I may not drive a :sleep: but that doesn't make me a very bad person. :chevy:
I think there's a reason for leadership. And it's good to have good leaders on this forum that don't just blow off their "whims" because they have power. It takes guts to admit something like this, and I'm sure I won't be the only one to forgive you.
So relax and have a beer. :confused:
General, you're not 21 so no beer for you :chevy:
crap, I always forget about people not being 21. :sleep:
Just secretly have a beer, and don't tell Jon.
So relax and have a beer.  :sleep:
Have no fear...I drank his beer for him...and many others. :chevy:
Don't worry about it General... :confused:
I drank one for you too. :confused:
Everybody makes poor judgement sometimes, but those who have good character realize thier mistakes and own up to them like you've done. Just chill and let it be in the past.
Think you hit the nail right on the head there Elwood! Dont worry about it General!
:confused:
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed. Why not updates as well, especially since some of those can be safety related also?
    • That's good to know, but I don't think I'll even be running them under 45 in the rear  unless it's on the sand or something but will only be for a short distance anyways!    I didn't read all the instructions in the booklet yet, but do you know let's say I set the rear psi on the placard to 45, will the warning light come on soon as it drops under 45 or is there a percentage it has to drop from the set value before the warning light is triggered?
    • That's bad.  Like, its probably destroying the stub axle the CV slides into.   Do you have a proper lift installed with differential lowering brackets?  Did you install AT4/Trail Boss factory CV axles?
    • Hot? New Jersey? Today? I was working on my old 2000 Silverado 1500 today. Believe me, it was boiling hot today. As it has been.
