Got some Audio/Video/Alarm upgrades!!!
Well here I've been talking about supercharging my 1500HD for some time now and what do I go and do?
I'm getting some serious electronics installed first:
Clifford AdvantGaurd 5 :cheers:
w/remote start
front windows up/down and cracked, rear windows up and down
Blackjax anticarjacking
dual zone shock sensor
self powered siren
dual zone proximity sensor
digital tilt sensor
Eclipse double Din DVD Navigation, DVD Movie, CD, MP3 with 6.5" LCD screen head unit (this thing is the $hit!!!) :chevy:
JL 1000/1 amp
2 Boston Pro 10's
custom fiberglass box for subs
JL 300/4 amp
Boston Pro 6.5 Components front doors
Boston 6.5 two ways rear doors
1 Farad Capacitor
WooHoo! what was I thinking? :)
peace.
:chevy:
Clifford AdvantGaurd 5 :thumbs:
w/remote start
self powered siren
digital tilt sensor
Eclipse double Din DVD Navigation, DVD Movie, CD, MP3 with 6.5" LCD screen head unit (this thing is the $hit!!!) :D
JL 1000/1 amp
2 Boston Pro 10's
JL 300/4 amp
1 Farad Capacitor
WooHoo! what was I thinking? :cheers:
peace.
:eek:
WOW! Nice system. Show us some pictures when it's installed. My cousin built his box for his truck-same as yours except in gray- and we had to make some adjustment to the rear seats to make a little room for the box.
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • Checked the pads today and there's plenty of meat on them. If the message keeps coming up, I'll just answer YES that the pads were replaced and wait for the squeal.
    • Welcome to the Forum! Always post the code definitions along with the codes. there are over 18000 possible codes, no one remembers them all and most will skip over your post rather than look them up
