Stock Lights on 99 Sierra ???
My99 Sierra has what seems to be an unusual problem with the right headlight. It has a dark spot toward the top of the low beam which 'sometimes' get larger. I noticed this while setting in front of a store where my lights reflected. I changed the H4 bulb to see if that helped but it did not.
Any help appreciated.
McBearBryant
1999 Sierra SLT
62000 miles
Welcome to the Forum :mad:
Sounds like you may have gotten some moisture in the housing,or the reflector is discoloring....composit lamp housings tend too do this as they get older....only way I know of to correct this is to replace the housing :wtf:
You should be able to find a replacement from 1 of the recommended vendors on this site...IF you choose this route....My '95 is doing this,I bought it used,the previous owner had a wreck and the left lhousing was newer,now the other 1 looks dull.... :cry:
OR you can check w/your dealer and see if they will replace it...worth a shot :chevy:
    ottogriffin
    ottogriffin
  • Who's Online   5 Members, 0 Anonymous, 718 Guests (See full list)
