Moving a truck across the country
DOGMAN
I'm buying a truck from Cali & want to bring it to IL.. Are there any companies that move vehicles cross country on flatbeds? Could someone give me some names or phone #s? Thanks
I would think it would be cheaper to buy a 1 way plane ticket, and just take a weekend to drive it back.
Sorry, I don't know much about those car hauling folks. :flag:
do a google search??? also, just look up cars on AutoTrader, they usually post ads about that inbetween car ads......
hope that helps. good luck
A friend of a friend sold a '72 K Blazer this spring. It was shipped from Pittsburgh to Washington State. If I remember I think it cost about a grand... I'll ask him at work today if I remember.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
