A Bel air, w/ 8 turbos???
LikeaRock14
Banks Racing has a 1200 HP Twin Kit, so I figure by their numbers this guy should be getting like ummmmm, 4800 ish HP?!?!?! So he's about 4000 off, crap tuning! Thats just too much money, and no women to spend it on!
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
