my wifes daily driver
droppedgmc
i just did an engine swap on it. took out the v-6 and put a 355cid in it.
these are pics after i waxed it for a car show tomorrow.
you can see the engine pics here
Looks good. There are some folks down the street that are selling a dark blue Camaro convert. of that vintage. It'd be nice, but I'm out of garage space not to mention money.
    contrabombarde
    contrabombarde
  • Who's Online   1 Member, 0 Anonymous, 870 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
    • No, we trade them like pokeman cards.
