New and Old compatible
Will newer heads (88 up) fit on a older (69) block ? I am trying to build a honest 350horse 350 engine. I have a 69 block, crank. A set of 327 pistons and lg journal rods. I just acquired a set of 89 heads and intake. What will interchange ???java script:emoticon(':D')
smiliejava script:emoticon(':D')
smilie
Yes on no, they will bolt on but intake ports will not properly match carb manifolds. If this is to be a carb engine , I would look for a set of old "double hump" heads with 1.94 or 2.02 intake valves and install steelite exhaust valves and hardened seat for them too.
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
