Help, no headlights
My auto headlights did not work tonight? I tried to turn them on manualy but that did'nt work either. It did this the other night for just a few seconds at start up then they came on and worked fine. Now the lights will not work at all? The "high beam" indicator light in the dash clustere is on and will not go off? Ayy one know what to do? the stealer, I mean dealer scares me. 1999, Silv.
Mike :D
This may sound like a dumb question,but did you check for a burnt fuse?:seeya:
p.s. How did you make out with your wiper problem?
The headlight problem is the headlight relay, I swapped out the ignition relay to check it. I need to get a relay. :thumbs:
The wiper problem is still there. I did pull the wiper motor cover off and cleaned the circuit board and contacts but they still come back up an inch or two when I turn them off :lol:
Thanks for your help.
Glad you found the light problem.....When you pulled the circuit board from the wiper motor,did you happen to notice the contact arm that comes off of the back of the board? was there a little "1/2 ball" looking thing on the end of that arm? or was it worn smooth/flat? If it was worn flat,it would throw the timing off for the park circuit.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 750 Guests (See full list)
