WTB mud flaps
Hey JBZ,
I put on a set of the Husky molded mudguards. My truck has flares, so they are shaped a little different than the non-flared versions.
I got them from here - they sell mudguards for trucks without flares:
Husky Mudguards
Not a bad fit for non-OEM. The fronts fit perfectly with factory running boards. Not sure if there is a fit problem with the nerf bars you have. But it looks like Ryanbabz71 had no problem with his.
I was able to use mostly factory holes. The fronts were easy - no new holes except one on the flap itself. The rear was a heartbreaker since I actually had to drill a hole in the metal on my brand new truck. :lol: Drill out the single piece plugs and buy new ones. Carefully pull the center piece on the 2 part plugs and reuse these.
I like the look - understated and matches the running board. I don't think serious off-roaders will trust these since hanging them on an incline might cause some damage. But they work great for keeping the everyday crud from spraying the side of the body and tossing junk on the running board. :seeya:
Hope this helps you out. :thumbs:
