16" x 9" Wheels
I am trying to finalize my plans for wheels and tires for my truck but I am debating buying a Weld Outback 16"x9".
Has anyone on here used a 9" wheel? If so, what is the max. tire size you would recommend for a 2003 GMC with Ford keys?
Thanks,
Stephen
Thanks for the input... still trying to figure out how much of a tire I can put on the 9" wheel with no lift (seeing that you have lift) and not have clearance problems. Any ideas?
On my 99 I was able to get the 285/75/16 on with no problem before I did any lift. I have heard that you can even go 305/75/16 without a problem but I know for fact the 285's will work. These were on the factory aluminum rims which I think are 16 x 8 or 8.5????
Arent the Welds in 16.5 x 9.5? I didnt know they offered a 16x9. I had a set of BFG 295/75/16s on my stock rims (16x7) on my stock truck with no probs. They would look a bit more aggressive on some wider rims like yours. And of course, when I added a set of the Phord keys, the truck looked wicked!
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 992 Guests (See full list)
