Help with alarm/remote start please
:D
Here is the deal. Just got a AST alarm/remote start put in the '02 GMC and now it is acting strange. I took it back to make sure the hooked up the right wires and they checked them.
Here is what happens.....Alarm works well, but when I use the remote start I will get the old "Engine Service Soon" light to trigger. I got the codes read and I am getting a couple of failures in the tranny. The failure is causeing the tranny to go to default mode (starts off in second gear :thumbs: ). The codes have been reset a couple of times but keep coming back. My guess is that something is not hooked up right with the darn remote start.
Anyone around here have any ideas or have seen this before?
Thanks in advance
Crisis solved. It was a matter of too many cooks in the kitchen. The pins on the alarm unit were not set correctly but the person that did the install let someone else set the pins. Since he held the unit upside down while setting everything up, it was not set right. The installer did not go back and check the other person's work. Only took three trips to the shop and 4 trips to the dealer to keep resetting the "check engine light" but it seems all is well on the western front now. Now the system is finally complete since I have an alarm to protect all the electronics in the truck. :D:thumbs::cheers:
I hope you didn't have to pay to get the BCM codes reset.
Hehe.....yeah.....especially since we made 5 trips to the dealer to get the codes reset. Its a small town and everyone pretty much knows each other so all it took was a trip down the the GMC dealership to get the equipment hooked up and the codes reset, no charge. Also learned that when you disconnect the battery there is a good chance you will trip the check engine light since there is a power (and therefore communication) interuption.
    • Would you supercharge the 6.2L on a 2021 GMC Yukon Denali XL with ProCharger?.... 605HP is the stated number without going crazy - it's not the LT4 682HP package, but I'm tempted to install it... This vehicle was ... not... recalled on the engine swap - but I don't really know if that means ...don't do it... or do it;)    Maybe i should start a prediction market pool on it in case it blows up;)   Any thoughts appreciated - I already OWN the supercharger - stopped the installation when the recall was announced and now it's taking up space in storage until I can solve an electrical issue with the vehicle...  4th GMC suburban-equivalent truck - I like them a lot - when they don't a) discharge their batteries randomly, or b) throw a rod at highway speeds;)
    • We tested the sleep mode with an ammeter in series with the negative battery terminal - 30amp fused - so we do know the actual shutdown and non-shutdown current draws and timing of the shutdown sequence.  We just have no protocol information to determine what module is issuing the network keep alive.
    • TrueBlue...Even if you don't have that info stuff displayed, If Mr. Computer thinks there's something you should know about, it will pop up a warning message no matter what else is being displayed. I keep the speedometer displayed all the time, yet the brake pad message pops up anyway.
    • BTW, the 11.5amp draw is all the usual systems active - it's not a single draw - that's the "we're all awake" state of the vehicle - forinstance if the power steps are actuated, the draw will spike to 22amps for that operation.  when the battery is disconnected and then reconnected, the vehicle shuts down that one time only - and we see a 10-15minute progression down 11.5  10.5  9. 8 6. 5. 1.6... 500ma... and then off to sleep at 40 milliamp... as expected.  So we know it's a module that is simply refusing to allow the SDGM to proceed to the sleep state.  We do NOT think it is the telematics VIM module - since we already duplicated the problem with the "VIM bypass" solution installed (we reverted that since it also disables the gmc app - but it does not appear that the telematics system is the culprit).  We've replaced the rear heater control module, tested without the wireless charger, and the other modules on CAN Bus 5 - but still something is keeping us awake and removing X2 from SDGM allows sleep to proceed.  We cannot diagnose from OBD since OBD drops off at about the 9volt level in sleep mode and we can't communicate with the vehicle - also we can't trace the SDGM internal packets from the OBD side - we have Autel Ultra.   Any ideas on why disconnecting X2 would allow sleep to proceed appreciated.  This is no longer a repair situation - this vehicie is simply unusable in this condition and NOBODY at GMC Dealer can even understand what it is doing.  This is crazy.  We made these systems too complex and now we're paying the price.
