Clear Coating Polished Aluminum Wheels?
Hi all...I just bought some new wheels for my ride. I haven't installed them yet as I'm looking into getting some clear coat applied (I hate polishing the aluminum to keep them nice).
Anybody had any experience with this?
Thanks!
Polishing is just what has to be done. If you don't want to polish, you should of payed the big bucks for chrome.
I've never heard of anyone clear coating polished wheels.
Yeah..Your right, GM and Ford do. I can have them laquered, but I know it'll have a fairly short life..like 2 or 3 years. I'm looking into clear powder coating right now. Shop I've talked to say their big customers are 18 wheeler's. Thinking about giving it a try. 30.00 bucks a wheel isn't to bad.
There are several polishing products out there for polished aluminum wheels that will keep them looking as good as chrome with regular polishing. I have had good luck with Heavy Metal Polish, Wizards Metal Renu, and Mother's Mag & Aluminum polish.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
