Un-Stock 2000 Z71
Hi! I´m new to the forum also. I just traded my 96 Sierra 5.7 for a 2000 Z71 w/5.3L. I need your help guys, I want to get more output form the stock engine but don´t know where to begin... It´s kind of a difficult task because I´m in Central America with little or no parts available, so I´ll have to order them, I´ll need all the info I can get, websites, stores.... I was thinking about an exhaust system and Chip upgrade or modifier....
Which is the best way to go? mmmm... I´m also on a $1000 budget....
Thanks for your replies, will be greatly appreciated..
:banghead:
Manuel Cifre, Guatemala Central America
2000 Chevy Z71 Stock
2003 Chevy 2500HD DURAMAX Diesel Stock
Heres what I am going to do to mine.
Flowmaster 40 series muffler, duals out the back.($300)
PCM for Less ECU($250) www.pcmforless.com
K&N FIPK($260)
Check out www.truckperformance.com or
T-Byrne Motorsports
sorry cant help but I just wanted to say welcome. Its nice to have people from all over the world as chevy truck owners :banghead:
Here is the list in order of what I would do:
1. Get a K&N FIPK (not just a drop in filter) and try to find it on Ebay. They are on their all the time brand new for $199 or so which is basically the cheapest anywhere
2. Get a free'r flowin exhaust in any brand (sound) combo you would like. A high flow catalytic converter would be a good step as well. ($2-400 typically)
3. A good reprogram can be had from a number of places. I personally do not have much experience with these. ($2-400)
4. I have seen/heard of significant gains by adding different roller rockers to the valvetrain assembly and getting 15-20 RWHP which isn't bad for the typical $150-300 range depending on the brand and size. I believe that these trucks have 1.8's or so. If you wanted short spurts of power, NOS is always a cheap way to go at virtually under $550 for a good dry kit. Easy install and is what most F-body cars are running and will give you adjustable HP.
Good luck and have fun.... :banghead:
Thanks for the info, I´ll start looking into the sites you mentioned. I was thinking about buying the Hypertech programmer.... what dou you think about it?
On the exhaust I´ll buy it from a local manufacturer, 4" from the manifold all the way back. And I´ll install the K&N for better breathing.... :banghead:
Thanks for the replies they are plenty helpful
Manuel Cifre
Guatemala, Central America
2000 Chevy Z71 LT sportside ex-cab
2003 Chevy 2500HD duramax ex-cab
Manuel Cifre
Most people say that they got very little with the Hypertech 3. I would go with Westers, Nelsons or PCM For Less before HPP3. If you want a handheld try Diablo Sport, SPE Proflash or Superchips before the HPP3.
With exhaust you do not want to go 4" or you will lose a lot of low end torque. A big no no in a heavy truck. If you go with true duals then your pipe size should be no bigger than 2 1/4". If you go off the Y-pipe then you can use a 3" in 3" out. or 3" in dual 2 1/2" out.
:D
    250.3k
    Pro Street Jim
    Pro Street Jim
  • Who's Online   1 Member, 0 Anonymous, 464 Guests (See full list)
