Remote Keyless Entry
My Remote Keyless Entry on my '98 Blazer was
working only a very short distance. I had to
be almost at the window to open the vehicle.
I did the tricks in the service manual to
reset the transmitters. One procedure
involves simultaneously holding down the lock
and unlock buttons on the transmitter. A second
involves holding down the lock button on the
vehicle and turning the ignition on and off
and the using the transmitters.
I did all this and the sensitivity was still poor.
In fact, it was terrible.
A day later, it seems to be working pretty well.
I can unlock the vehicle from 25 feet away.
What's up with that? Any ideas?
Should I replace the receiver? It would be
easy enough; it is right under the dash.
What do receivers cost? Would the transmitters
have to be reprogrammed? Can I do that myself?
...or would a dealer have to do it?
When was the last time you replaced the batteries in the transmitters? That'd be step #1. The receiver is in the driver's footwell, on the black panel the ALDL is connected to. I found mine yesterday when installing something else. It wouldn't be hard to replace, but I'd try the batteries first.
Also, when the transmitter started working well again, was this in a different location from when they weren't working well, or was it a different transmitter? If you were in a different location, there may have been interference of some kind that was messing it up.
The batteries are fine. I checked one with a voltmeter
and it was like 3.25 volts -- pretty good for a 3 volt
battery. Just for hoots, I replaced the battery anyway;
there was no difference.
The Blazer was parked in the street. I'm in a pretty
open area. There was nothing really near it.
I found another thread with a similar problem.
The original poster ended up having the receiver
replaced under an extended warranty.
Any idea where I can get a good price on the
RKE receiver?
$76.46 plus shipping from www.partszoneonline.com I just looked it up. Sorry, can't find a part number. Go into the GM catalog, select your vehicle and search Mechanical. Then go into "Electrical" then "Body Electrical" on the menu on the left and you should find the RKE components.
  • 1 month later...
I finally got tired of my remote keyless entry
performance and broke down and went to
www.partszoneonline.com for a new receiver.
I installed it today and have to say, "Nice!"
Now, I can lock/unlock my Blazer from about
sixty feet away.
I see there is one adjustment in the receiver
box -- a coil. I wonder if tuning it would have
made any difference. If I had any spare time,
I would experiment with it.
Thanks again for your help.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,157 Guests (See full list)
