RPO Codes
Z71  Off Road Suspension
Z82  Trailering Provisions HD (Not Available For Export To Europe, China, And FSU)
Z83  Solid Smooth Ride Suspension
Z85  Handling / Trailering Suspension
Z88  GMC Conversion (Available On All Domestic Models, Required For The Middle East)
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
