Anyone using the Bully Dog Allison Shift Enhancer?
Bully Dog's info -
The simplest, most effective kit available without having to pull the transmision, the new Allison Shift Enhancer literally gives the clutches more traction in the clutch packs. Which allows for a quicker shift, and 50 HP worth of additional holding power for the Allison 1000, 2000, and 2400 transmissions.
I have one coming in for my HD on Tuesday. Just wondering if anyone has tried this yet.
Tom
2002 8.1 Silverado HD - Full Throttle lift, 37" tires, Comp Cam, TOG headers, Volant induction plus more!
2002 8.1 Suburban -Intercooled Whipple supercharger, 22" wheels/tires + more - 407hp/558 ft-lb torque at the rear wheels - 13.93 @ 95.79 MPH
www.tbyrnemotorsports.com
Tom, please keep us posted as I have not heard or read of anyone using this...very curious as to whether or not it does as claimed....if not it looks like a Suncoast upgrade for me......cha-Ching
Looks like a partial Trans-Go kit. Gotta drop the tranny for that though, but is part of the Suncoast beef-up.
This is more of a band-aid....even less than the Trans-Go. Now the weakest link will most likely be the torque converter.
    bellssn690
    bellssn690
  • Who's Online   6 Members, 0 Anonymous, 579 Guests (See full list)
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
