Avalanche Billet Grill
I just put on my new billet grill and I was a little "shocked" at the install. The grill simply "covers" the existing factory one and is anchored by a bolt/toggle system. Is this typical? I thought I'd be removing the stock and "filling" in the hole with the new billet.
This type of install also somewhat compromises the ease of getting to the hood release. I can still release the latch with my finger but it's very "crowded".
let me know any thoughts!
If this is totally lame I may return it!
Brad
what brand is it?  I know stull replaces the whole grill on the silverados
Glad to hear you got your grille. Did you order it through TRENZ? Mine came in a plane white box , but has their logo on the grille itself.The quality is very good. I know what you mean about it going over the factory. I was surprised about that too. I have installed a ton of billet grilles and most require cutting and or trimming.They may have designed it that way to make it such an easy install. I bet it still looks good.
The compromising of space is normal with most grilles. (at least a little bit)
Did you use the rivets?Did you have to reshape it at all?
I bet you will get compliments on it and decide to keep it.
Hey Matt,
I had a buddy of mine who owns a shop in HB order it for me. I didn't use any rivets. The grill came with a toggle/bolt system to anchor it to the stock grill.
Mine also came in a plain white box, and the grill itself was protected by "shrink-wrap". It does look good!
I emailed you about your gas-cap cover yesterday. Can you hook me up with one?
Thanks
Brad
Brad,
I wonder if you did get a TRENZ grille.It doesnt sound like it. When i got mine they asked me what i thought about the install and i told them I didnt think the rivet was installer friendly.
Does your have welded thread bolts on the grille and come with wing nuts?
My gascap was a sample for SEMA. We will be selling similar ones very soon. I looked and they are out-of -stock at the moment.
Email me in a couple of weeks(because i may forget) and I will check again.
Is the shop 4wheeler supply in HB?
