No power to AC compressor on 92...
The AC quit working in my 5.7L 92 recently. It has a good charge, but the compressor won't kick in. I have used a test light to check all the wires on the AC pump and can't get power to any of them regardless of wether or not the AC button is active or not inside the cab. What's the next step?
This may sound like a dumb question,BUT did you check the fuse? After that I would check the low pressure switch thats mounted on the accumulater. If there is enough refrigerant in the system, you should have continuity across the terminals, use a DVOM (Digital Volt/Ohm Meter) or a simple continuity tester will do, just unplug the harness and probe the terminals to check that it is closed...If the circuit is OPEN (no continuity) the switch may be bad OR there may not be enough refrigerant in the system...You can also check for power(+12V) at that switch w/the ignition switch ON,and the A/C switch ON...If there is no power at all, it may be best for you to get a wiring diagram and start tracing the circuits...If you are not comfortable doin it yourself, have a shop check it out instead of throwin parts and $$$ at it...just a thought...GOOD LUCK :jester:
Fuse is good, I'll move on to the other things you mentioned. Anyone else got any idea's?
Thanks!
    ballencd
    ballencd
  • Who's Online   6 Members, 0 Anonymous, 634 Guests (See full list)
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
    • I have both but typically use the 4 legged walker (wheels on front, ski's on back).   The four wheeler is starting to be used on "longer" outdoor walks.  The 4 legged walker is particularly helpful in practicing good walking posture.  Both of my knees are at different stages of recovery and I'm trying to not develop poor habits.  I can actually manage with a cane but it's very difficult not to favor one leg over the other.  My PT recommends I continue with my 4 legged walker for a while.  Yesterday was four weeks since my last knee replacement and I'm excited about my progress to date.  It has been a hell of a rough journey so far but it is exciting to witness  systematic and continuous improvement.  I went for years watching the decline of my "mobility".  It seems that everyday now I am alerting my wife to something I can do now that I couldn't a day or two ago!  I encourage anyone facing the prospect of knee replacement to share any concerns with others who have had the surgery.  It isn't an instant fix but rather is a considerable amount of short term pain for long term gain.  Recovery time and pain levels vary for individuals post surgery but the end results are typically very positive and I've never encountered anyone regretting having had the surgery.
    • The lifter issue can be dealt with by shorter oil changes and quality oil IMO.
    • Got heavy rain, hail and light rain yesterday.
    • I'm putting in an A-pillar pod/gauges, and I'm asking if anybody can identify a (preferably) fuse for a switched power and illumination circuit on the driver's side interior fuse panel. Offhand, everything I checked with a test light was constant-hot, and I'd much rather uses a piggyback fuse. I can certainly find a wire, but I'd rather not half-tap.   Thanks in advance for any help.
