Flickering Lights
Going down the road this morning I noticed my radio light and gear indicator/mileage lights flash on and off. They'll be fine for minutes at a time and then out of the corner of your eye I'll see them go off and then come right back on. After watching them a while I noticed that sometimes the gear/mileage indicator lights would only dim and not go completely out, however, the radio lights still go out completely.
This seems to happen independent of anything I do and I can't "make" it happen. It is also daylight hours and I don't know what would happen if at night with the headlights on. Also, I don't see any indication of a problem looking at the alternator gauge AND the truck doesn't indicate any other problems such as cutting out or "hiccuping" when this occurs. Help please.......
rikhek
99 NBS 1/2 ton
It's not just the radio...As stated I also see the gear indicator/mileage lights go out or dim at the same time.
Thanks for your assistance. I take it a bad rheostat would give the intermittent systems I described?
Where is it located and what does it look like?
Thanks in advance.
rikhek
