it the g 80 locker different on a 3/4 ton than a 1/2 ton is it stronger?
I think the only major difference is size of the case, the bigger it is the stronger it is, but I'm pretty sure the operation is the same...but I could be wrong..all I know for sure is that I have a 14bolt, 9 1/2 in w/a G80 that works pretty darn good for my uses :jester:
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
