Wester's Tune Opinions
Got in on the Wester's GP offered by TByrne and I'm trying to fill out my questionare.
Truck: 2000 Silv. Extra Cab Short Box 4wd, 5.3L, 4.10 gearing, 285/75R-16, No mods except K&N air filter and tires (from 265 to 285).
Truck is a daily driver. Tend to haul dirt bikes around in back don't tow anything over 4000lb.
TUNE: I'm leaning toward the 87/91 dual tune. I normally buy 87 octane gas and premium here is 92.
Is there any significant advantage to the 89/93 tune in terms of performance or fuel economy? I would go this route is there is benefit to the extra $ spent at the pump.
TORQUE MANAGEMENT: From what I've read in the last few weeks, I think I will remove "most all".
TRANNY: I want him to firm up the shifts in the tranny, but I have issues with the way the stock programming shifts. The truck has a dead spot around 45-50mph. It likes to sit in OD at about 1100-1200 rpm (where this engine seems to make very little power) and I have to put my foot into it pretty hard to get it to shift down and then it screams. I either need to gain low end power or change the shifting to keep the RPM's up. Will raising the shift RPM's effect this or does that just effect WOT?
Also what is the stock speed limiter set at? (If I haven't hit it then I probably don't need to raise it.)
Thanks for your time. All opinions are welcome.
Scott
    • Most say the oil temperature needs to above the boiling point of water to rid it of moisture and long enough to dry it. Many think that is about a hour at 212 F or more. Those people have never line dried cloths in a Midwest winter. Leave a pan of water sitting on the counter and eventually it all evaporates. So heat drives the time it takes. Water in oil under 175 F, the Nitration initiation temperature, is a minimum then for temperature and samples I've done that use Karl Fisher method say about a hour (in a healthy well tuned motor) over 175 F will dry it to under 800 ppm. Low enough to not be much of a factor. Motors with weak rings will take longer and the colder the air temperature the longer it takes.   On a cold motor there is also the condensation temperature. Blowby gases that contain moisture are subject to that cold cylinder wall, like sweat on a glass of ice tea. But also subject to the Law of Partial Pressures. Wear studies by GM and the DOD  indicate wear is a real issue below 85 F and a concern to 140 F but doesn't become a minimal factor until about 160 F. You know this intuitively when you see water vapor exit the exhaust pipe until the system gets above the dew point. It isn't magic, it's physics and it fascinates me. I know you didn't ask but....I over share sometimes. 😉    You keep the Camaro's high and tight.
    • Move further away.   Benefit of living out - none of our cars get short cycled, plenty of warm up time.   Curious how much time/temperature it takes to drive moisture/condensation out of the engine?
    • Switch a a 100% synthetic trans fluid, Amsoil works for me.
    • First of all sorry, I know there are a ton of transmission temperature threads...   My truck is a 2025 LZ0 High (10l89 10-speed) High Country with NHT max trailering package. The NHT package is supposed to have "enhanced cooling."   Normally the trans temp sits around 200. It seems like with any real stress it quickly jumps into the 220s (for example climbing a grade unloaded at lower speeds). I haven't towed much with this truck, but I'm concerned if it gets this hot unloaded.    I've tried a few different things to keep the temps down (tow/haul mode, sport mode, low range when that makes sense) and nothing seems to affect it.    I'm curious if others are the same behavior or if anyone has found techniques to keep the temps down. It seems like it just can't handle reduced airflow at lower speeds, even with relatively light loading.    Thanks!
    • I'm at 105,000 miles on my baby Duramax. No issues yet. I hit 31 mpg's traveling through hilly terrain to a project in Colorado. I will buy another 3.0. I'm not concerned.
