what size pipes?
what size is the oem muffler on the 6.0? mainly wandering how long it is? Am i reading right that i have 2 3" in and a 3" out? guess i need to crawl up under my truck and look it over in genral. all this time i thought it had single exhaust all the way. was thinking either a 3" in with duel 2.5 oo one with 3" in 3" out, glad i didn't look like an idoit at the muffler shop.
Now I guess I'm looking for a duel 3" in single 3" out, hopeing i can use the stock exhuast pipes that way.
went and looked again on flow master, biggest pipes in to there mufflers are 2.5, well duel in anyway. they had some sort of cone things that reduced from 3" to 2.5", think they'd be worth it?
I have a 2004 6.0 as well. There are two pipes and cats going into one muffler with 2 3inch inputs, and 2 3inch outputs (some say only one output if fuctional) that go to a Y pipe then into a single tail pipe.
Here is what I did. I cut out the stock muffer and tailpipe secion. Put in two Magnaflow 18 inch mufflers side by side, then each muffler has a tail pipe that dumps before the rear axle. The system sounds great, no drone, and my milage has gone up. Also run the Diablo Predator tune and AEM cold air intake w/6 inch Superlift, 35 inch tires. Sounds great, looks great, runs great. Good luck.
    • We've done a bunch of them.  Very common failure.  They don't sell the park position switch separate from the shift control assembly which is stupid, because they ended up selling a switch on some other products like 2016-2019 Malibu, 2018-2019 Traverse, 2019 Blazer, and another car or two as those were having the same issue for years (but these have a console mounted shifter not column mounted).
    • .30” of rain all month and it’s been weeks since that. “Mowed” our two properties today for the first time since July 2nd. It only took 30 minutes because all I had to do was level some weeds and saplings in a few problem areas. Everything else is dead.
    • Dealer reported a failed shifter module assembly so the whole shifter is getting replaced. Yet another premature repair… up to $12,000+ in extended warranty payout in only 5 years and 80,000 miles!
    • According to the dealer it’s an internal leak/failure of the compressor.  Again, another failure that shouldn’t happen at only 5 years and 80k miles.  For some reason the compressors must be hard to come by right now, because the truck’s been at the dealer almost a week and they just located a compressor at another dealer several states away today.  We’ll see if this fixes the issue.
    • I'm not sure if this should be a reply on this thread or a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - ACDelco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles. When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so i did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance.
