viscous clutch
Help,
I have a 2001 Denali with about 80k freeway miles and started experiencing the front end chattering whenever I make sharp turns at slow speeds. I have been told by the dealership that I need to replace my transfer case for a whoppin $2,500 but it is covered under warranty. Unfortunatly, I didn't get a warranty so here I sit trying to avoid writing the check. I am frustrated about buying a $40k truck that can't make it to 100K miles without a major repair. Has anyone else experienced this problem?
Joe,
I have not heard of any problems at all with the vicous coupling in the NVG149
transfer case. The whole case would not need to be replaced anyway, just the vicous coupling. Used transfer cases can be found also, I see them on Ebay every once in a while.
Butch 02 Sierra Denali (with the NVG149 case)
I have experienced this with my mom's old Jeep Grand Cherokee, it's a common problem for them. I've never heard of it with the Chevy's, but it sounds like that is what's going on with your truck. The transfer cases are similar in design as far as I know.
make sure your tires are all the same size, type, same wear, and pressure
i don't understand why they can't replace the bad parts in the t-case instead of
the whole unit.
the whole unit.
Yea, I hear that, should be able to split the T-case and replace the viscous clutch.
thanks for the response from everyone. I thought (was hoping) t was the tires so I had them replaced and measured them. Still chattered.
Here is what I found out. The replacement part (viscous coupler) from the dealer is $750, but I made a call to Drivetrain Specialist and I can get it from them for $400. By the time it is all said and done with a rebuild kit (since it has 80K) I would be into it for about 800. I can get a rebuilt transfercase from them for 850 (with all new internal parts), so it sounds like a no brainer. Got one on order and going to slap it in when it arrives next week. I still get a 12,000 mile warranty which is all the dealer would give me if they did it @ $2,500.
