"Service 4x4" message, solutions?
My truck has done this a few times to me, when it does it none of the push button lights come on and 4x4 isn't available. Now, I can shut the truck off and restart it most of the times, its fine. Any common reasons for this? Btw, I think thats the message it says, "service 4x4," or maybe "Check 4x4."
I agree, Try a new switch first,part #15709327 which lists for $55.95.
Theres even a bulletin on it that says to replace the switch for the "SERVICE 4WD" light if its on. :)
is the truck still under warranty?
my new silverado z71 did the exact same thing....
i took it in 3 times for that problem, first i was told that the "computer" wasn't programmed correctly at the factory, 2nd time i was told it just needed to be "reset"......third time they actually replaced a sensor that was"reading too high a resistance".
take your pick but, it's not the buttons in your dash.
There is a bulletin on the encoder motor sensor but it effects the'03 model year only,not the '99.
Yep,The one on the dash,not hard to change at all. :lol:
