Power problem
Hi all,
I have a 98 Silverado, 1/2 ton. Recently, I have replaced the battery, alternator, and most of the battery cables, with the exception of the long one that runs to the driver side power center.
I still have a power drop to 12 volts on the guage when I run the lights or AC.
Any idea on what to check? I am going to check the ground that goes to the frame next to the battery tomm. I know the one that runs to the block is good.
Could have a bad or corroded ground somewhere or possibly a junk alternator. Is the alternator new or reman? I've personally had bad luck with reman electrical parts. (alternator,wiper motor)
Or you could drive around at night with the lights and ac off...nothin like sweatin in the dark while driving...pretty safe :thumbs:
It does go back to 14 volts if those things are off.
Where is the voltage regulater? I thought it was inside the alternator.
You are correct, it's inside the alternator.
One problem might be the size of the alt.
Anyone know if this truck should have the 105 or 120 amp alt? No one seems to know which one is takes.....
Check your RPO codes. Here's the list from the '98 list posted elsewhere on this board:
KG9 Generator, 140 Amp
KW2 Generator, 124 Amp
KXB Dual Generator, 100 Amp
K60 Generator: 100 Ampere
K68 Generator: 105 Ampere
    overspeed
    overspeed
  • Who's Online   4 Members, 0 Anonymous, 309 Guests (See full list)
