2004 disc brake bias
My 2004 silverado is heavily biased toward the front brakes. With the load I have on it I need more rear brake. I believe I have found the proportioning valve under the drivers side frame rail. It appears that there is an adjustment there. Does anyone know how to adjust brake bias on the 4 wheel discs?
YEP, No adjustment,what you found under the drivers side frame rail is the ABS module and the brake pressure modulator valve.
    ballencd
    ballencd
  • Who's Online   1 Member, 0 Anonymous, 506 Guests (See full list)
