Installing Fog Lamps
Guest chevydeerhunter
I'm looking to install factory fog lamps in my '03 Silverado that didn't come with them. I found some on eBay for about $120 a set with the wiring harness and switch. I'd also like to have total control of it's use instead of only being able to use them with lo beam only. Has anyone done this retrofit and how difficult is it?
They're easy to install, don't even have to have the computer reprogrammed like on the 99-02's. R&D used to sell a controller to keep the fogs on, but I guess they are out of business now.
Is that right, you do not have to have the computer reprogrammed on 03-04 Silverado's. I did not know that. I had a 01 GMc and had to have the dealer install because of that. How are they wired?
I installed them myself on my '04...easy and worked instantly...no programming required.
Very easy instructions that tell you exactly what to do and how to do it...I WOULD NOT pay a mechanic to install as it's very easy and about an hours worth of work at the most.
Very easy.
I too bought from eBay and installed them myself easy!!! The wires on my 04 Sierra were already there, just cut the holes in the air dam, mount the brackets, change the switch in the dash, plug in the relay and done. About a hour to do since I am kinda anal about my truck. :lurk:
    • No I didn’t watch a video of a person who analyzes oil for a living explain general oil usage. For clarity I did ask my brothers one who runs our equipment business. The other who runs our old ROW business about oil usage. Nothing has changed since I retired. Their personal vehicles or work vehicles use no oil. Not enough to see on the oil checking device. Then I pondered. I like to ponder. In this extended oil changing world with oil change countdowns or lights. If engines used say a qt every 2500 miles or up to even 4000 miles. With oil changes reaching as high as 15000 miles. Normal for most people is eight to ten. Vehicles should potentially be seizing up all over the place. Especially in hilly terrain. Just how many people actually check their oil? Maybe 10 percent. Those are the people that probably change their oil early. I like to research used car listings. I have five favorite dealers I check. They all list carfax with their listing. It’s rare to see vehicles with anything but extended oil changes. Transmission service, forget about it. I’ve seen Honda and Toyota certified vehicles up to 100K miles and ten years old. With nothing but normal maintenance. Isn’t nice we all have different experiences and believe our way is the best. You certainly get backup for whatever you believe. Life would be boring otherwise.
    • Interesting rumor. Dealers near me have been tight-lipped so far, but if this reveal actually happens next week, I'm really hoping they finally give the HD a proper interior overhaul. The competition has been eating their lunch in the cabin department for a while now.
    • There are a few good takeaways in that video that pertain to this thread, certainly the possibility of the oil control rings having buildup, the fuel injectors and how clean or not that they are ending up affecting the pistons rings carbon buildup, and the fact that its normal up to a point for a given engine to use some oil, and that the oil quality that is being utilized is part of that ring clogging up issue as well.   I was talking with a neighbor yesterday who has a baby LZ0 duramax and he had bought it slightly used but it does consume some oil and he has switched over to 5W-30 Euro spec oil and in this case that never made a difference in consumption over the factory 0W-20 recommendation. He finds it uses a quart in about 3500 miles and as he goes a ways over that distance he adds oil to full and goes another 1000 miles or so and then changes oil and is typically at 40% or so left on the oil monitor at that point with his use case of quite a lot of highway miles and more limited in short run use. I don't know what other LZ0 engines are doing for oil consumption but that is what his is doing.
    • I dont care what Lake says. Goodnight.
    • Ok well I guess Lake disagrees with me on a few points. I call oil consumption pretty basic. Rudimentary. He calls it "really complicated." I think 1qt consumed in 3k miles is a lot. He says that's normal. In 22 minutes, he'll use his natural talent to explain oil consumption to anyone watching this video. He covers everything from obvious engine damage to how normally functioning healthy engines consume oil by design. Lake explicitly states how you drive will impact oil consumption.   Shut up and watch:
