Andretti: paces LMS test
Elwood
J Andretti: paces LMS test
by Fanball Staff - Fanball.com
Friday, October 1, 2004
News
John Andretti, driving a second car for ppc Racing numbered 14, led NASCAR Nextel Cup testing at Lowe's Motor Speedway, with a speed of 181.75 mph.
Views
Kyle Petty was the second fastest car, with a speed of 178.92 mph.
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
