Silverstar Sale - Heads Up
Just wanted to give you guys a heads up that in my area Murrays is running a sale on all their sylvania lighting. 25% off. Got a pair of silverstar headlights (had one burn out a few months ago) for $30 (plus i had a $10 gift cert from buying a set of brake pads so I got em for $20)
The lows and highs have worked great since the install just before Christmas. My fogs are out though. I tried to use them a few weeks ago and they wouldn't come on, yet the switch light was on. Put the old bulbs back in yesterday and they lit. So I'm contacting Sylvania like Ryan did...darn things have probably less than 2hrs operating time since being put in.
    bellssn690
    bellssn690
  • Who's Online   4 Members, 2 Anonymous, 831 Guests (See full list)
