Fluids on 4x4
Hey everyone.
I was wondering which fluids should I use in the front and rear diffs as well as transfer case. How often do I have to change those type of fluids. I am missing a manual so this is the alternate and a better information source. Thanks.
I have the GM service manual infront of me right now:
They don't call for any fluid changes for the differntials (they state to just check level and add as necessary). Fluids: Front 80W-90, Rear 75W-90 synthetic.
Transfer case: I am getting ready to do mine tomorrow (this is why I have the manual out), it's supposed to be changed every 50k miles. I assume that you have the same transfer case as mine (NVG 263), this one takes 2 quarts of Dexron III.
I am changing mine over to Mobil 1 synthetic ATF.
Thanx alot shooter. Good lookin out :cheers:
Do regular auto parts stores sell these fluids like autozone or pepboys, or is it like a special order thing. Im pretty new to the 4x4 scene and the entire truck scene period.
I wanna change all the fluids including ally flush. I did find allison fluid for 35 bucks per gallon for transynd here locally. Is that expensive? :cheers:
You should be able to find the fluids locally. At least here in NC the Auto Zone has a good selection.
AMSOIL makes a direct replacement for the Transynd fluid. If your interested let me know and I can get you a price delivered to your door.
Local Autoparts stores cary the fluids, I bought my Mobil 1 ATF at the Autozone.
$35.-/gal is pretty high. Our local Allison dealer sells 5 gal. for around $130.-.
My next project for the 75'000 mi service is to change my transmission fluid to synthetic, also, but I will use Mobil 1 as well which is also OK to use in the Allison.
Make sure that if you are going to buy any Allison spin-on filters to buy them from an Allison dealer (not GM). The Allison dealer charges about 1/2 (approx. $9.-).
