Another Texan
Stocklook
Just to say hey, I'm old school with a new truck
04 ECSB RED Silverado LS 4.8 soon to be tuned (TQM is :thumbs: )
I can't spin the tires at all, My 02 ECSB same set-up would run circles around it
