Its Me
kc7dcw
Hi guys, Tim here in Beaufort, SC.
Currently I have a Cheverolet 2000 Silverado 1500 ext cab long bed with the 5.3L (Wifes truck). I drive a 1996 Surburban 2500 with the 454 (7.4L).
Looking at having my engine rebuilt next year with some goodies put on it. The 'burb is my daily driver and also used to haul a 7,000 lb travel trailer.
Looking at getting a '89 Silverado 2500 ext cab short bed next year from a friend when he buys a new truck. Need a project and wife gave me the go ahead if he does sell it. Yeah.
:thumbs:
