DMax Pipe
I have a stock 03 D/A. I want to pipe it for a little extra on the HP and torque numbers. I also dont want it to sound like a semi. I going to eventually add "the Juice"(edge products). What pipe is recommended for this application? Prices?
So many options, SS :nono:
DPPI makes a system that's easy on the ears for around $699, or so
Banks makes a good system but it's a little louder
Summit Racing has a 4" economy, aluminum system for $299, and a stainless system for $399. It almost sounds like a straight pipe, though.
Kennedy Diesel has a 4" system that is also quiet - 2 mufflers to chose from, as well
I run the DPPI system on my 2500HD and I'm very pleased with its sound and volume. The only time it's a little too loud is when I'm pulling from a dead stop.
I like DPPI so much that I just installed another system on my F-350. In addition, the DPPI cooled my egt's by about 150*
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 843 Guests (See full list)
