Vibration in steering
I have an 01 Suburban which I just bought. The truck had a noticeable vibration at highway speeds when I test drove it, so I jacked the front end up to check. (truck has 100K on it) Both front wheels can be moved side-to-side a fair amount, but the play does not appear to be at the tie rod ends, as I was expecting. The steering is somewhat loose, so I tightened the steering box but it made no difference. Any suggestions? I didn't think much of it when I made the offer on the truck but then I hadn't read up on all the steering issues GM seems to be having with these trucks. The truck has brand new tires, so I can't detect any wear patterns. Obviously, it has been doing this a while. Also, this may not be related but I did happen to notice that the steering column does NOT lock with the ignition off & key out.
First thing I would check is wheel balance - out of balance wheels often cause vibration at speed that is not noticeable at lower speeds. Is the vibration in the steering wheel?
No vibration in steering wheel. I'm thinking of changing tires front to back to see what happens, but based on the amount of play in the front end I don't think it's going to help.
Yes, if it's not in the steering wheel I would think it is something other than wheel balance. Good luck.
As far as looseness in the steering goes, other things to check besides the tie rod ends include the idler arm and center link...possibly the pitman arm also.
try jacking it up...grab the tire at 12:00 and 6:00 and see if there is any play in it from top to bottom. I had a hub go bad on me, caused some bad vibes..
MIke
MIke
That type movement can also be bad ball-joints...$$$
As to the original question..I agree with budhayes on the idler arm/pittman arm. My 89 went through them like candy, and my 92 is no slouch at eating them either.
For vibration, there are a multitude of things that can cause it.
-Bearings
-Tire out of balance/round
-Ujoints
-Steering componentry
-Too much coffee
-Not enough coffee
-Tranny
-Rear end
Those are in no particular order, of course. :nono:
No play up & down. I don't think it's the bearings or hubs, since both wheels have the same amount of play. There seems to be some play at the pittman arm but I can't tell if it's in that or in the steering box. ( I *think* it's the box.)
Take a good look at the driveshaft like Wingnut listed in his post. They can be out of balance and will cause a major vibration throughout the truck. It is a known Chevy problem.
    Brendan C
    Brendan C
  • Who's Online   1 Member, 0 Anonymous, 856 Guests (See full list)
