Hello
JRHDCrew
Hi Everyone
Guess I should introduce my self after my first couple of posts.
I just bought an 04 Chevy CrewHD, so far I love it but I could have used a little better gas mileage.
I didnt really want the HD but I need to plow my own driveway.
Dealer basically talked me into it because I would have voided my warranty with the 1500.
My last truck was a 97 GMC Ext cab with 155000 on it Traded it in and got my HD.
I will like the extra power for trailering my Boat and Snowmobiles so the HD wont go to waste.
Anyway the whole new truck experience is going well.
Anyway Its a nice site, Im sure Ill be around now that I now its here.
John
