RLR20 thinking moments
SnakeEyeSS
I don't know if anyone else here knows what "red letter rock 20" is(its a weekly christian rock top 20 show. it's host are some of the funniest guys I've heard on the radio, when it comes to their things to think about moments. they play the "skit" like a public service annoumncement. today, their anniversary show, plyed all their best ones. they are pointless, flat out stupid thing. say it yourself, ya gotta hear it out loud to appreciate it here i my fav:
[deep voice announcer] ANd here's something to think about. to really,.... really,....really,really,really,really think about. HARD. REALLY HARD.
[host] you know I think superman and santa are the same guy
[other host] huh? [speechless]
[host] because they can both fly, and they both have beards
[deep voice announcer] and that was something to think about. to really,.... really,....really,really,really,really think about. HARD. REALLY HARD.
BROUGHT TO YOU BY:
coin operated ATM's, put in a little, get a whole lot back
here's another:
[host] you know, a childs face say's a lot!
[other host] ah oh.........oh no
[host]especially the mouth part of the face
And there's something to think about. to really,.... really,....really,really,really,really think about. HARD. REALLY HARD.
I'm e-mailing them asking them to put up the clips on their site, hopefulyy they will so more can laugh
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
