Great day for a fall ski ride.
Stepside Z
Temps in the 80s, leaves changing color, big boats rolling through the intercoastal waterway, big wakes, and big air.  Life could not be sweeter.
Haha, glad im not the only one. I went out for about 2 hours today and froze my ass off. I neglected to wear my wetsuit. Didnt really think id need it. But man oh man that water was cold.
    bellssn690
    bellssn690
  • Who's Online   4 Members, 0 Anonymous, 705 Guests (See full list)
